clubstylus - View topic - Unfinished Stylus RT For Sale - Now Sold
It is currently Fri May 29, 2020 2:40 am
Post new topic Reply to topic  [ 5 posts ]
Post Unfinished Stylus RT For Sale - Now Sold
Its time to sell my unfinished Stylus. All of the following has been stored in my dry, brick-built tiled-roof garage.
2003/4 Tim Benbow-era De-Dion chassis. Powder coated and overcoated with grey smoothrite.
Mk II Escort rack with SSC extensions for RT.
SSC supplied coil-over shocks, chosen for road use.
1988 2l Pinto Sierra donor which is still held on SORN.
Parts used from donor: Engine, gearbox, diff, drive shafts, front and rear hubs & brakes, handbrake, steering column, stalks, wheels (temporarily).
Drive shafts shortened by Fibreform.
Engine rebored to 2.1, crank ground and flywheel lightened. Head refurbished and gas flowed by me. Rather too lairy cam fitted.
Vernier pulley, RS2000 alloy sump, twin 40 Dellortos. Non-vacuum distributor, electric fuel pump. Basic electronic ignition.
RT body shell, DB5-style bonnet vent, Tim's revised door hinges and passenger door fitted.
Lower dash and carbon-look dashboard with full instruments fitted.
The car was run and driven to the top of the drive and back a few times in 2009.
The following loose items will be supplied.
Top tint windscreen
Drivers door
Smoked headlight covers.
StylusSprinter front anti-roll bar kit.
Rollover bar
Soft top and frame
New front discs.
Mini wiper mech.
File of receipts, build manual, useful info etc.
Inspection is recomended, PM me to make arrangements. The car will need to be trailered from WR4 postcode.
£3,000.
Fri Apr 07, 2017 1:09 pm
Post Re: Unfinished Stylus RT For Sale
Multiple photos would help
Fri Apr 07, 2017 6:40 pm
If you decide to break it, I'll have 1st dibs on the light covers.
Fri Apr 07, 2017 8:50 pm
Thu Apr 13, 2017 3:00 pm
This vehicle is now sold. The new owner has a wealth of professional and personal support available to him. I wish him well with the car and hope will make himself known to you all.
Ill leave him to introduce himself to you.
Fri Apr 28, 2017 4:05 pm
