Diff's
Put your parts wanted list here
Diff's
If anyone has a 4.1 English diff in really good condition that's not required for the future , I'm in the market for one :wink: No intention of changing now but it's a planned back-up if my 13 inch wheels change has more effect than my calculations re - top speed :oops:
norma
Re: Diff's
Post by norma »
If you go to 13" wheels, then top speed will drop?
Don't you need a 3.54 to compensate?
(forgive me if I have the wrong end of the stick)
Re: Diff's
norma wrote:If you go to 13" wheels, then top speed will drop?
A 3.54 would be way too high geared and put me back right where I started with the 15 inch wheels. 13's will drop me 8mph top end , a 4.1 will get me back to 140mph plus.
ianminki
Re: Diff's
Post by ianminki »
good morning rob
think I mite have one but in need of repair. the bearings have gone on near side wheel side all the teeth look ok just made a horrible sound when in car.if u could explain how I should check the ratio your welcome to have it .regards ian
Re: Diff's
ianminki wrote:good morning rob
Not sure how many teeth each ratio has , as always bought previous diff's as listed :roll:
Re: Diff's
4.44 = 9 / 40 (pinion teeth/crownwheel teeth)
4.125 = 8/33
3.89 = 9/35
3.77 = 9/34
3.54 = 11/39
ianminki
Re: Diff's
Post by ianminki »
looks like the one I have is a 3.54 according to mattd's little chart with prop flange bolt center's are 45mm x 55mm if ita any help to u rob regards ian
Re: Diff's
ianminki wrote:looks like the one I have is a 3.54 according to mattd's little chart with prop flange bolt center's are 45mm x 55mm if ita any help to u rob regards ian
Thanks for thinking of me Ian but with a 3.54 diff , I'd need 300bhp plus to be competitive and that would cost more than I can muster to supercharge my engine plus all the other bits needed to run it/new Atlas axle & gearbox etc.
