clubstylus - View topic - Big brakes
It is currently Mon Jan 20, 2020 4:54 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Big brakes
Post Big brakes
Wed Feb 27, 2008 10:40 pm
Post Re: Big brakes
Thu Feb 28, 2008 12:55 am
Post
Thu Feb 28, 2008 2:09 pm
Post
Thu Feb 28, 2008 2:42 pm
Post
Suffolk
Thu Feb 28, 2008 9:18 pm
Post Re: Big brakes
can i ask whats wrong with Hi Spec, i have them but havent tried them yet.
Could you not just use cosworth fronts? very cheap and easy. I would look at making some thing up. I made the big brake kit for my last RX7 using M5 front discs and the new shape rx7 four pot callipers with spacers. I went from 275x22mm to 330 x30mm, once i sorted the bias and stuck some hawk pads the brakes were out of this word, they easily realed in the 460 bhp and out braked my mates 997 porka on the track without ABS which was a very nice feeling. The whole kit cost me less than £200. To go out and buy one was about a grand.
You obviously dont need that bigger brakes, but its very easy to make something fit, especially on the kit car where everything is that much smaller and the ford pattern is easy to buy for.
The FD RX7 calliper is a nice light 4 pot unit which will fit under a 15 inch wheel on a a 275 mm disc, you pick them up very cheap and race pads are easy and cheap to pick up, just a though if you fancy having a play.
Thu Feb 28, 2008 11:56 pm
Post Re: Big brakes
I think you will find that Cossie calipers do not fit on a standard Sierra upright. Or at least the ones I tried didn't :(
Suffolk
Fri Feb 29, 2008 12:40 am
Post Re: Big brakes
Fri Feb 29, 2008 12:41 am
Post Re: Big brakes
Fri Feb 29, 2008 9:33 pm
Post Re: Big brakes
Don't go bike calipers, they're not designed to stop a 700kg car.
In the dutch kitcarclub there's one that didi it on a bec and they caught on fire.
Mileage striker 4age-16v twin DHLA
Fri Feb 29, 2008 9:36 pm
Post Re: Big brakes
I've only ever had 247mm disc's . Vented to start with then solids once I realised vented was overkill. You need good stoppers on track for quick laps and my Willwood then Raceleda 4 pots plus Hawk Black pads are an awesome combination . My solids were originally 9mm , slotted and drilled but overheated and cracked so now have standard 12mm solids without drilling or slots :roll:
Sat Mar 01, 2008 10:27 am
Post Re: Big brakes
I've got two options at the moment - either solid 257mm from rally designs or I've found a set of front and rears from a Radical that are 240mm vented, the rears have no handbrake option though....
Does anyone have a discount card for rallydesign?
Sat Mar 01, 2008 4:38 pm
Post Re: Big brakes
anyone interested in a group buy for a new wilwood brake kit, if there is interest I'll investigate a price.
Sat Mar 01, 2008 4:55 pm
Post Re: Big brakes
Sat Mar 01, 2008 9:10 pm
Post Re: Big brakes
Suffolk
Sat Mar 01, 2008 11:40 pm
