clubstylus - View topic - Bottom swivel
It is currently Mon Mar 30, 2020 7:54 am
Post new topic Reply to topic  [ 11 posts ]
 Bottom swivel
Post Bottom swivel
Bottom swivel
(Front suspension) QR 1774RHT
The above is the quoted bottom ball joint on the Stylus - is this the one for the escort upright (and the sierra with an added conical shim) or is it one that fits the Sierra upright only?
I have measured the Sierra upright for the taper of the lower ball joint, details as follows:
Top (smallest diameter) = 14.5mm
Bottom (largest diameter) = 16.5mm
Depth of taper = 16mm (this is the length over which it must taper).
Once I get the above question confirmed I will look to see if I can find a part specifically for the Sierra upright, then when anyone comes to change, or wants to change, they will have an option - no guarantee there is a perfect fit out there.
Q.
Sun Jan 06, 2008 8:02 pm
Post Re: Bottom swivel
Sun Jan 06, 2008 10:41 pm
Post
Sun Jan 06, 2008 11:22 pm
Post
Are the rockerarms for the Sierra and Escort upright different? If not, I would just get some escort uprights and replace the sierra units.
Mon Jan 07, 2008 1:56 pm
Post
Yes Escort or equivalent would be the thing to do, but I bought the car as a rolling chassis and that is a package of uprights, brakes, pads and discs - I would have to expend too much to change when I have had no use out of what I have currently bought.
I will over time look to replace the Sierra uprights, but not in one go.
Number 1, get the car on the road and in use.
....then upgrade - Steering wheel first (want a quick release wheel), springs possibly combined with the rear radius arms then look to upgrade brakes and front uprights.
I will have to set a priority order and that may get upset by essentials I find I need when driving it.
I should have insisted on Escort uprights when I ordered the car, I did not know just how much of a compromise Sierra ones were.
"Are the rocker arms for the Sierra and Escort upright different? " - still need this answered though.
Mon Jan 07, 2008 2:19 pm
Post Uprights Sierra/Escort
Mon Jan 07, 2008 6:31 pm
Post
Mon Jan 07, 2008 7:11 pm
Post
Mon Jan 07, 2008 7:50 pm
Post
Mon Jan 07, 2008 9:19 pm
Post Escort uprights
Tue Jan 08, 2008 1:25 am
Post Update
Mon Jan 14, 2008 9:35 am
