clubstylus - View topic - MSA compliant rollbar
It is currently Wed Feb 20, 2019 12:58 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
Post MSA compliant rollbar
Question to the forum although I suspect its really one for Matt D...
I want a rollbar that will pass the new requirements for 2016, it needs to be taller than the original offering and have rear facing stays - I currently have a fury rollbar that is 2inch taller than standard, but it has forward facing stays so is no longer compliant.
Is there one available from SSC now or in the near future that will fit the existing chassis?
Fri Jan 01, 2016 1:59 pm
Post Re: MSA compliant rollbar
The stays need to be attached at the top of the rollbar then slant down at 30 degrees and be welded to the chassis rails. Height wise , there's no fixed height , it has to be personal to you ie. with your helmet on sitting in the car , the bar MUST be 50mm above the helmet. In my case that means 23 inches from memory but that's no guide for yours.
Fri Jan 01, 2016 4:38 pm
I thought your rear stays attached midway, aren't you also going to have an issue with scrutineers?
Re: "must be welded to the chassis", I've been through the bluebook forwards and backwards, bolted in is fine:
"1.3.3. Backstays. These are compulsory and must be
attached near the roofline and near the top outer bends
of the main rollbar on both sides of the car. They must
make an angle of at least 30° with the vertical, must run
rearwards and be straight and as close as possible to
he interior side panels of the bodyshell. Their materials
specification, diameter and thickness must be as
defined in 1.4.1.
Their mountings must be reinforced by plates. Each
backstay should be secured by bolts having a
cumulative section area at least two thirds of that
recommended for each rollbar leg mounting in 1.3.2
above, and with identical reinforcement plates of a least
60cm2 area (see drawing K19).
A single bolt in double shear is permitted, providing it is
of adequate section and strength (see drawing K20)
and provided that a bush is welded into the backstay.
The mounting feet may alternatively be welded direct to
the reinforcement plate."
Fri Jan 01, 2016 5:07 pm
I may well have trouble with scrutes but we'll see . If I do then that'll be the end of my Stylus competition years. If I spend money it'll only be on the classic Alfa because it won't lose money :!: When I say welded I mean't the chassis fixings that the stays '' can '' bolt to. ie the tubes that pass through the chassis have to be flush with the outside of the tubes and MUST be welded at BOTH ends. This is why I've not done anything. It really is a major job/cost on a car already built --- easy if you're building at the pre - body fit stage.
I do have crush tubes but not welded.
Fri Jan 01, 2016 5:21 pm
I get your clarification, that makes sense.
I was looking at doing a few sprints as I've enjoyed competing in autosolos, the rollbar and tyre list uncertainty have certainly created a pain for kit cars and added to my planned expenditure which will ultimately mean less events this year.
I am also struggling to find competitive 1a tyres in 13inch, A539s are old technology and take too long to warm up, so I'm now looking at rainexpert 3s in 185/70 rear and 175/65 front, and sticking with Avon CR500s for 1b.
Fri Jan 01, 2016 5:44 pm
The Avon CR500 's are good in wet and dry but best dry tyre in the new rules will be the Toyo R888 R's --- get the softer one's if you get a choice.
Fri Jan 01, 2016 6:07 pm
Forward facing stays are acceptable on open cars. MSA 2016 K 1.6.2
Height of bar 50mm above helmet line with a minimum height of 720mm from top of seat cushion.
Dont know if that helps.
Fri Jan 01, 2016 9:20 pm
Cheers Kev, that's useful to know on a future design, but mine had 35mm stays and minimum is 38mm.
Sat Jan 02, 2016 12:29 am
Mon Jan 04, 2016 3:51 pm
Mon Jan 04, 2016 4:10 pm
Mon Jan 04, 2016 8:59 pm
48.3mm's is what I have :wink:
Mon Jan 04, 2016 9:15 pm
Mon Jan 04, 2016 9:47 pm
I have re-read.
The reason for having an MSA certified ROPS enables you to - design outside of the listed scopes (doubt anyone would without good reason) & use a lighter material (as the quality, bends, design, weld should be of a very high standard, hence superior protection). So your £5k investment gains you weight & quality basically.
Otherwise follow the rules.
Matt - for my new chassis :wink: I would prefer the 48.3mm fixed to something a tad better than 1" Square chassis. Due care on weight/design considered. The Caged Phoenix (?) chassis design is ideal from a race spec point of view.
But I couldnt see a reason to not make a common Stylus ROP with a standard nominal height. As a guideline Im 6.2 to 6.3 without helmet an my top hoop is 1020mm from floor. I have the original fiberglass seats with no padding.
Just as a suggestion though.
MSA Link https://www.msauk.org/assets/2016bbcomp ... -res-1.pdf page 158 onwards
Mon Jan 04, 2016 9:50 pm
It would be attached to the rear chassis sides which are 50x25mm
Mon Jan 04, 2016 10:36 pm
