clubstylus - View topic - Retro fit independant rear suspension
It is currently Sun Jan 19, 2020 3:29 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
Post Re: Retro fit independant rear suspension
Had a bad weekend, car dynode at 410bhp at the wheels on Wednesday, but over the weekend did not finish a race due to problems with the waste gate after a few laps, did not get in a clear lap to get a best time, but it went from 18th on the grid to 4th in the first lap running with guys who can do 2.24's my best lap on the old suspension was 2.29, and it was beating cars that were all over me last year through the fast sweepers. So I am declaring the suspension mode a success. Can't upload pictures but there are some on my face book same user name.
Mon May 27, 2013 1:01 pm
Car is still down on power due to heat soak into the injection system, vaporizing fuel, but the weekend I had the car driven by a professional driver, who declared the new irs rear end as perfect, I managed two wins even with the serious loss of power against cars that left me for dead on the handling last year so I am declaring the irs as a success.
Now working on seriously lowering the car and softening the front springs, both of which will mean serious body work to raise the front wheel arches.
Apart from this working on fitting a fuel cooling system, and supporting the inlet system as it is so large we are getting cracks in the welding on the plenum chamber when it is only supported by the manifold bolts.
Mon Sep 16, 2013 8:26 am
Mon Sep 16, 2013 2:18 pm
https://www.youtube.com/user/FlyingHaggisRacing
Here's a vidio of the car with the new suspension, taken from a mates 328, the 328 had a fueling problem as you will see, it nearly stops a few time, my car had a major power problem, the ECU cut out when the VTEC cut in to change the cams so I could only rev to 5800, (the car revs to 9 and has 450 BHP when it works properly, which I hope it will for the next race
Had a problem with cracking the the pipe in the inlet sytem between the turbo and the inter cooler, turned out the front spliter is generiting so much down force that it 'stretching' the pipe and riping it from the turbo, remounted the intercooler so it stays fixed relative to the turbo.
The civic is seriously quick,
Any way you can get a good view of the new IRS at work from this vidio
Thu Oct 17, 2013 8:02 am
Tue Sep 18, 2018 11:36 am
Thanks Rob,
A timely reminder. But where to get the suspension arms and diff mounting plates?
Are Siltech doing upgrades yet?
I need to call in and see Matt
Wed Sep 19, 2018 2:00 pm
Wed Sep 19, 2018 3:39 pm
A new building!! Product Evaluation for Improvements!! OMG!
They are really rolling their sleeves up and aiming high.
They will probably still be ready before me. Iv just got to make a doorway into the barn big enough for the Stylus. But with 750mm dry stone walls & tree trunk roof supports - I keep finding easier jobs to do.
Wed Sep 19, 2018 8:25 pm
I picked some parts up from Siltech a couple of weeks ago, they were talking about replacing the front suspension to take outboard shocks .
We will see.
Keith
Suffolk
Wed Sep 19, 2018 10:39 pm
Thu Sep 20, 2018 1:25 pm
Users browsing this forum: No registered users and 0 guests
