Here is the progress from the last few months..
To start with, Here's a few pics of the crap removed from the car
Left, the mass of electrical tape, literally everything was taped up, & on the right a spaghetti of wire!
Here's some pieces of fibreglass, aluminium & various other sh1t which was riveted, bolted or stuck to the car!
Next task i set about was to make a new firewall,
I started by making a flat piece of fibreglass by covering a piece of polycarb panel with release wax then covering it with
numerous layers of both chopped strand (CSM) and 3 layers of woven roving's to add some nice strength,
once I had my flat panel I then cut it to shape & trial fitted it,
here's it is held in place with some tape,
I also added a small strip the width of it to the bottom
I then stuck a strip of tape underneath so the resin didn't drip all over the car & glassed the 2 pieces together
I then removed the panel from the car & added extra re-inforcing layer of fibreglass on the inside edge
After that I prepped the area for glassin by grinding the old joint smooth
After that I measured up the holes & matched the new fibreglass panel to them.
Then smeared tiger seal all along the bottom edge popped a few rivets in place
View from the inside, All nicely sealed
