Could you not find a clear one then? shame really the white does not quite go does it sorry to be so blunt!!MattD wrote:Gonna run with a clear version of this aeroscreen & see how it goes.
Hi PetePeteC wrote:Slightly off topic, but what is that material you are using as a screen? I've been looking for some sheeting that will hold its shape after heating to make inner wheel arches. How did you shape that?
Pete..
Hi TonyAntnicuk wrote:Sorry for the thread hi jack Matt, how long do think it will take to get yours finished and shaken down?
Also, where would suit?
MattD wrote:The white one is the test template, made from foam sheet.
Used it to check shape & hole positions.
Should have the real one cut from clear polycarbonate for next weekend.
A friend has a plastics business, so it's a CAD-CAM profile sent straight to his flatbed cutter.
Cuts one in less than a minute, so very easy now to try different designs.
