This should really be in a different topic but thought I'd better follow it up here after the previous report.
Well I stripped the brake pedal out then started looking at every tiny detail as though building it again. When first fitting it the bias bar was already mounted so didn't know what the mechanism looked like. I assumed it to be a sphere with threaded centre , held in the centre by circlips or whatever . Not at all , it's more like a 5mm wide disc of the same diameter as the tube and the threaded rod adjuster is part of it left and right . Each side of the disc is another smaller disc to restrict rocking angle . SO ---------- That got a polish as did the inside of the tube . I also chipped off the powder coating around the ends of the tube and polished them too. Bearing in mind trying to acheive the pushrods being parallel , I measured the distance apart the master cylinders were -- centres . That was 2.5 inches. Got some 2mm thick 1.5 inch washers to place each side of the tube. Then cut 5mm off the length of the longest rod (to the smallest cylinder -- front brakes) as it was previously 10mm longer as supplied . So now the difference is 5mm -- not --- 10mm between rods. As I started to reassemble the clevices to the rods mounting them at 2.5 inches centres apart on the bias bar -------- I realised that if I screwed them home all the way into the clevis as some sites advise (and I'd previously done
)----------- it would stop the centre of the clevis which holds the bias bar from FREE FLOATING when braking
So I screwed them home then back one turn to clear the clevis barrell . Finally checking the 5mm rod length difference. Also on assembly I soaked the lot with WD and copper greased the washers both sides . When fitting the pedal pivot bolt I tightened it then released it so that the pedal fell back easily.
Possibly this combined with washers and correct distance apart plus lesser rod length difference MAY be the answer
Just need to remove the COOKED hawk black pads that are breaking up and replace them. Shame cos they were still 8mm thick
Worst problem for me though is not knowing if it's sorted untill a test day can be had
as it's not road going
One further thought , that my cousin brought up , was mounting a return spring on the brake pedal
This seems a cheap and fairly simple thing to do so might put my brain to work on that idea
There's not much chance on actually fitting a spring to pull the pedal back to resting position BUT I could fit a coil spring between the pedal and bulkhead with a little thought
Then if non fast return really IS the cause regardless of set up then that should sort it
