Posted: Thu Feb 21, 2008 11:26 am
Thanks, nice looking car you have there.alecmartin19 wrote:hello and welcome!
Yeah ok for that reason I can see the benefit, but that's a 'problem' I have at the moment and choose to take my chances - though it's nothing a bit of kevlar wouldn't resolve. There are lots of potential areas for paranoia, flailing prop shafts is a favourite of mine.alecmartin19 wrote:i would say yes to the seat pans needing to be made from steel, unless you want to run over something at speed and find it lodged in your rear end!
Oh sure I agree with you all. I'm not aiming for a featherweight, otherwise I guess I'd be building that r1ot after all. But it's easy to pile the pounds on, I've seen it, my Westfield is heavier than I would like, but theres not alot there that I don't think needs to be. And as for stiffness, I'd definitely be fitting a cage, which does make a significant addition (at the price of weight of course!).alecmartin19 wrote:i agree with rob too about the chassis stiffness is more influential than shedding a few pounds. i've just fitted 2 strut braces to my nissan skyline to stiffen it up further and it makes quite a bit of difference. you could almost feel the body flexing before. especially the front wings. not now!
same applies to the chassis. if it isn't strong but is light, it will still be under the same forces and the light one will eventually have flexed enough, work hardened the material and then crack and cause you to crash! Nasty!!
Can anyone answer the approx weight of a finished Stylus question? Or is it shrouded in secrecy
