Springs - Again !
Re: Springs - Again !
If the chassis is out of align front to back, can you not adjust where your rear axle sits with your adjustable panhard rod to compensate?
Yes you can but adjustable panhards are not standard plus it's better if the chassis is close to correct in the first place. Even after F/F cut the towers off mine and re-welded them in position , I still made an adjustable panhard to fine tune things. My question to Jeff was '' does he know whether his chassis is staightacrobin wrote:If the chassis is out of align front to back, can you not adjust where your rear axle sits with your adjustable panhard rod to compensate?
Don't get me started on the quality of the powdercoating.jefferybond wrote:. Welding and powdercoat looked OK, but just general carelessness in it's assembly.
Jeff
Let's just say surface prep must have been non-existent. It peeled off very quickly.
I've rust proofed & smoothrite'd all the bits I can see / get to over the last 9 years.
- jefferybond
- Are you a Stylus owner?: no
I think I did once the wheels were on, maybe not with string but by sighting along a straight edge. Looked close enough to me.stylussprinter wrote: But did you string it out to check front to rear in line
Jeff
