Re: TWMC Goodwood TONHIRE SPRINT 28TH June.
Posted: Mon Aug 18, 2008 4:18 pm
Wishbones welded up and painted ready to fit
Here you can discuss kitcar related stuff
http://clubstylus.be/forum/
Yes , that's right . One new and the original pattern from the passenger side. The billet uprights are gold adonised and I had the gold hammerite anyway from doing the rear drums years agoWerner Van Loock wrote:looking good, made 2 new ones, or is it one new and the original good one you also painted?
Nice recovery, Rob.stylussprinter wrote:Managed to get it rubbed down last night then up early this morning to give it 8 coats of VW Red Flash in a spray can. The arch extensions I did with a brush but this area's so much bigger and more obvious , it had to be sprayed. It'll show anyway on the join . I considered rubbing down with wet and dry when the paint's 24 hours old but not having done it before , I'm not sure what the result might be![]()
Any paint experts out there![]()
MattD wrote:Nice recovery, Rob.stylussprinter wrote:Managed to get it rubbed down last night then up early this morning to give it 8 coats of VW Red Flash in a spray can. The arch extensions I did with a brush but this area's so much bigger and more obvious , it had to be sprayed. It'll show anyway on the join . I considered rubbing down with wet and dry when the paint's 24 hours old but not having done it before , I'm not sure what the result might be![]()
It's amazing how resilient & repairable GRP is.![]()
Are you happy with the final finish ??NOT REALLY -- that's why I'm getting on with the mechanical stuff that I understand BUT it is repaired at least , just looks obvious re- the paint
Just image the work if that had been a nice Ali bodied historic !![]()
Matt.
