Holiday visit
Re: Holiday visit
must be some engine to be reving to 77000rpm
Re: Holiday visit
a 2 litre zetec (i assume) has to be pretty special to make 230 bhp..... no wonder you want to look after it.
Re: Holiday visit
Yes , it is a great engine . Paul Dunnell has a reputation for getting more from a Ford , torque wise , than most . Don't forget she was pulling 8300 rpm on the dyno and still climbing however my limit on budget meant it had to be held to 7700 rpm , on a regular basis for track work . He's always cautious and rightly so when you consider the cost. He would have been quite happy to let it rev' to 8300 rpm for track work if I'd gone for a dry sump. Everything else is there for it to produce 240 bhp plus (he has zetecs producing 270bhp and more with steel crank/rods etc ). His torque curve only varies 7 % from lowest to highest lbft
plus it's virtually flat against other tuners print outs I've seen , with similar bhp
Aaron Scott drove it once and was impressed with it's mid range grunt . Tim's also been on track in it and was surprised too , even though he knew its power on paper .
It's taken me a year to use that new found grunt at the top end to lower lap times , basically because it means cornering in a higher gear and flat than I previously did ---------- it's a ' mental ' thing ---- your brain tells you it can't be done ---------- so you need to by-pass that function and try it
That's my phylosophy anyway ------ your brain can stop you looking at things clearly OR trying something out
especially if you're an OAP
Re: Holiday visit
Matt's got me an invite to the charity day in place of his own car (thanks Matt
) so I'll be sharing track time with his friend who's taking either a race prepared ' E ' Type or a Cougar Jaguar ---------- Matt's squirrelling away pennies for the next build
So a learning curve starts on the 9th Oct.
Snetterton here we come
A last little outing before storing ' her ' away for the winter
Re: Holiday visit
Not going to happen now I'm afraid after my Eelmoor tree hugging sessionstylussprinter wrote:Matt's got me an invite to the charity day in place of his own car (thanks Matt) so I'll be sharing track time with his friend who's taking either a race prepared ' E ' Type or a Cougar Jaguar ---------- Matt's squirrelling away pennies for the next build
So a learning curve starts on the 9th Oct.Snetterton here we come
Re: Holiday visit
Matt told me last night that after fitting the ARB up front , it totally transformed the track performance when he was at Snetterton
Nice to here when a plan comes together
Apparently an instructor told him after sitting aside him driving the track '' this works , doesn't it '' (meaning the whole balance of his car)
Thanks for telling me Matt
What a damn good night out last night was aye
--- The FDMC dinner dance / 50th anniversary of starting the club
