Liphook Tonight
mikeb
Re: Liphook Tonight
Post by mikeb »
80hp at 60% throttle. o.k'ish, but I've forked out quite a bit for the spec of the engine. A Westfield has the only other engine at this spec but running Jenvey45's instead of my bike TB (46mm butterfly) and smaller exhaust primaries 1.5" instead of my 1.75". This engine made 237bhp and 180ft/lb of torque on Northamptons rollers. I'm hoping for just a little more. mike
kevp
Re: Liphook Tonight
Post by kevp »
Wow. Perhaps your cams are very wild, & not ready to start work at the lower revs?
mikeb
Re: Liphook Tonight
Post by mikeb »
I hope so. Troy's answer of 'o.k.' to my question 'how did it perform' was a little underwhelming.
Re: Liphook Tonight
mikeb wrote:I hope so. Troy's answer of 'o.k.' to my question 'how did it perform' was a little underwhelming.
Mike , I wouldn't put too much credance on N M Sport's rollers ----- mine came out at 157bhp after calculating the transmission loss to get a flywheel bhp . FRANKLY , I consider Paul Dunnels dyno of my engine before fitting , showing 243bhp at 8300rpm a more likely figure , particularly with the way it now performs. (not having a dry sump the rev-cut is set to 7750rpm which reduces it to 231bhp)
mikeb
Re: Liphook Tonight
Post by mikeb »
Troy at NMS praised Dunnell as an engine builder but did add that he thought that many engine builders tend to exaggerate outputs.
but what do I know?
I'm hoping that I can get close to that feeling of acceleration in the 300bhp pilbeam I sprinted at Curborough in '99. Or maybe just enough to properly shock Tanya!
Re: Liphook Tonight
mikeb wrote:Troy at NMS praised Dunnell as an engine builder but did add that he thought that many engine builders tend to exaggerate outputs.
but what do I know?
It wouldn't match the handling though aye :P lucky you 8)
peteb
Re: Liphook Tonight
Post by peteb »
Hi Mike,
I'm just down the road from Northampton Motorsport and was thinking of putting my car on the rollers to see if they could sort out the idling issue, it won't keep running at less than 3000rpm (or could be 1500rpm as the tacho and laptop are disagreeing :D ). Its running a 2ltr Zetec with an OMEX ecu and standard injectors. Would you recommend Northampton Motorsport? Cheers Pete
mikeb
Re: Liphook Tonight
Post by mikeb »
I was asked by Simon Armstrong, the bloke that supplied the bits, to take it to NHMS. It's only half mapped, but so far so good.
A quick search of Blatchat and the Westfield forums shows that both NHMS and Emerald in Norfolk are the places that get the vote of confidence.
Mike
Re: Liphook Tonight
mikeb wrote:I was asked by Simon Armstrong, the bloke that supplied the bits, to take it to NHMS. It's only half mapped, but so far so good.
Mike
I would definitely agree on EMERALD , he's an absolute wiz and very sound figures :wink: Another ' wiz ' is REDLINE at Court Industrial Est near IVER , around the M25 --- an old but very clever guy .
Re: Liphook Tonight
Getting this thread back-on-track - its Liphook meet this Thursday evening.
I won't be there myself, as I'll be working down at the Goodwood Revivial this weekend.
Re: Liphook Tonight
It's on this week, usual time, usual place :-)
Ned
Re: Liphook Tonight
Post by Ned »
Sadly we wont be there Marnie working nights at A&E and i have to collect my son from the ferry at 10pm, so a beer for me please :( :( :( :( :(
Re: Liphook Tonight
Short Notice I know, but it's on tonight, usual time, usual place.
Ned
Re: Liphook Tonight
Post by Ned »
This thursday is the meet, Marnie and i are eating there around 7.30 and will try and nab a table/seating area for around 9pm so there is space as its busy there with xmas dinners. :D
Re: Liphook Tonight
Tonight is the first meet of 2011.
Hope some can make it, I'll be there around 8 / 8.30.
The Mrs is even threatening to come along.
