ANY CONTACT?
Probably best at night for callsPete&Matt wrote:Has Tim been in contact with anyone yet? He was supposed to call me back a few evenings ago and hasnt so far and isnt answering his mobile now! Ill be patient up untill the Exeter show, then ill get the bits i want from there if not!
hi pete and matt
I managed to speak with him this morning about 9.30.
this sounds daft at first i know but if you need to speak with hiom in th eday look what the weather is like in his area as he is up a ladder painting most of th etime if it is fine .
today it was lashing down so he was doing a bit on my brothers car
hope that helps malcolm
Building for older brother .
Yes , I have . I may see him next week to talk over things in the pipeline that I've said I'll also produce . Werner mentioned wishbones - kinked etc . It would be nice to produce a complete chassis with the latest spec'Pete&Matt wrote:out of intrest, has anyone spoken to Tim recently?
Many thanks Kevin , that might be useful if you weren't in Southampton but can't see you running all up here to give me a hand. I'm quite enjoying organising things and upgrading as I go. Mainly manufacturing methods now that the first kits are sorted. Found a good ' coating company ' and busy sorting another way to make brackets . Also looking at using CDS tube as opposed to steel solid to keep the weight down . I can now get coating ZINC in satin black , although it is about 3 to 4 quid more expensive per kit. All these things I'm gradually finding answers for. Perhaps if Tim doesn't get down to see me before xmas , I could be in touch . BIKE POWER would be quicker than 4 wheels
Thanks for offering
Thanks for offering
if you do buy SSC or produce the stuff with Tim, one thing i think would be a good starting project would be the body! Those doors are a right pain in the arse and so are the hinges! im sure there has to be a better way of doing it! Fisher cars have a similar process but the hinges seem to be far simpler and easier to install!
To be honest once I'd done the 1st door the other was a doddle . Regarding Fury doors ---- talk to owners who've had their car a year or so ------ they droop a lot. My hinges , designed by P.Powell , were VERY heavy but have held up well over the last 8yrs. Tim's new LIGHTER ones are as good I think BUT much , much lighterPete&Matt wrote:Rob
If I could get at my hinges --------- OUT THEY'D COME
The inner door's easy enough as it's not critical because F/Glass can be trimmed off from the edge to align the outer door skin. Personally , I didn't use the strips of alloy around the edge method --- all seemed too much work for a lazy arse like me
If you glue it as Tim does then you can glass it at the same time or day at least
Very few of us have his latest kit anyway , so can't see how much easier it is to build now
