Re: More work & £££ !
Posted: Tue May 08, 2012 11:04 pm
yep still lurking, this place was really helpful.
You may find that you had boost creep, especially if you had a bigger turbo, a free flow exhaust can cause creep even on stock turbos so you may not notice on short bursts but keeping your foot in can see high boost.
Not sure i want to tell you that i bought another M3 to replace the stylus
i wanted something that i could just use as a toy that didnt need much work or maintenance. I still have a series 1 RX7 which i am in the process of fitting the latest RX7 running gear in and a wide arch body kit. Fancy some old skool but with modern performance and handling.
