Antnicuk wrote:I need to set up my suspension and found this thread, My camber on the front is looks at quite an angle. I have a feeling the suspension is going to need a lot of tweaking but i want to start by getting the front geometry correct.
I have read the above but not quite sure what it means or how to do it. Could anyone give me a simple how to guide? i also need reminding which way is positive and which is negative?,
NEGATIVE = wheels leaning into the body at the top (what you need
POSITIVE = wheels leaning away from the body at the top(vintage only
I assume i have to set the height i want first? Is there a reccomended height? and where is it measured from?
THIS ONE ISN'T EASY --- because I've not seen your car so have no idea what length shocks(open-closed) and springs you have(length & lbs)
The ride height will be effectively limited by all the above UNLESS your budget can afford to change them. Assuming you can't do that then --- RIDE height(measured under the front lower 50 x 25mm chassis tube) needs to be 25mm ''lower'' than the RIDE height at the rear(measured under the join of alloy floor to steel seat pan -drivers side)
Shock adjusting platforms should be set so that there is PISTON travel (the shiny 12mm rod showing through the spring coils) of 25mm at the FRONT.
When you set the rear shocks to acheive the 25mm higher ride height --- check what piston travel is visible (hopefully it will be more than the front)
THESE adjustments will give you the ride height BUT is a guide only because spring lbs will control how much of the piston travel you WILL need
ALL THESE adjustments assume weight being on the cars wheels
I want a setting that will be ok for a little bit of road use and track days.
TRACK & ROAD -- it would be a good starting point to set TOE at straight ahead OR only just IN (wheels pointing towards each other) The track rods on the ends of the steering rack WILL adjust that.CAMBER -- set it to 1.5 NEGATIVE until you've got experience under your belt --- i.e. when you corner very fast you will get more roll therefore you'll need more negative camber so that the tyre is sitting flat through the corners onto the tarmac ---- there are ways to limit roll but that's another discussion when you've got started and WANT MORE
TYRE PRESSURES --- depends how heavy you are but MAX 20 psi all round ----- I run 17psi (tyre makes vary on result 2 to 3 psi)
I'm also not sure what shocks and springs the car has in it. The shocks are red and i think they are AVO, are these standard fitment?, if so, should i keep them? my springs on the back are blue if this means anything, when i took it round the block i had set all four shocks to max firmness and it rattled my teeth. I have now set to soft and will try again.
SHOCK CLICKS ---- count how many clicks there are on your shocks from low to high --- set the FRONT at 1/3 rd of the total & the REAR at 2/3 rds
CASTOR --- you will have very little control over this on a standard kit so I'd leave it alone at first build setting ---- it can be altered by design £££££
BUT also a little with standard wishbones using great care. A later discussion perhaps as there's so much that will effect your handling .
FINALLY --- with all that grunt you intend having -- FIT one of my FRONT ARB kits ----- this will reduce roll plus rear wheel lift in cornering -- therefore MORE GRIP
I've been over this subject many times and the above is a guide because it's not my car or driving style nor can I see the result --- driving it on track will allow you to better understand what the car is doing under very hard cornering which will lead you to change these settings .
DOES IT UNDERSTEER , OVERSTEER etc . I think I've covered everything
Any recomendations welcomed.
