Blog
Stylus related discussions
Werner Van Loock
Blog
Post by Werner Van Loock »
You can check out my blog at http://werner.clubstylus.be
hearbear
Post by hearbear »
Nice feature werner :D The inlet manifold are you buying or making it yourself :?:
Werner Van Loock
Will make it myself, much like the following:
But in fiberglass then. And probably using the plastic inletmanifold of the mondeo, lighter and fiberglass bonds better to plastic then metal.
Re: Blog
Werner Van Loock wrote:You can check out my blog at http://werner.clubstylus.be
Hello Werner , I've started to build up my blog so thought I'd give the site address to all. I just typed up the whole 2002 season from memory and the odd referal from other reports THEN submitted it to the blog and promtly lost it :o Ah well , it must have been me so I'll do it another day. Not trying now cos Matt's just arrived to stay the night cos we're off to EXCEL tomorrow to see the London motorsport show. Maybe see something I like ?
Regards , Rob.
http://redmistracing.clubstylus.be
Werner Van Loock
Rob,
When you make posts to the blog you should keep some things in mind.
1st don't post too much at once.
2nd before you push the post button, just select all you text and press CTRL-C (or right click and select copy).
This way it's on your clipboard and in case something goes wrong, you can just paste it again.
Other trick is to type everything in notepad and copy it from there.
I'm investigating to use a different blog script as this one isn't too stable apparently. It was added by the provider, so decided to use it, but I don't thing they tested it touroughly.
blog use
Thanks Werner , will do :D
Schrodinger
Post by Schrodinger »
Werner
I see from your blog that you are making your own plenum, do you have a throttle body & bypass valve for it?
I have one knocking around in my garage along with a mount for the bypass which you are welcome to if it will be any good, they came from a similar plenum for Ginetta.
Keith
Aviemore
Werner Van Loock
Thanks for the offer, but I'll be using the original throttle body and ICV as I will also be using the stock ECU. If that doesn't work out well, then I'll go for a VEMS ECU
