Quaife gearbox views
Shooter63
Post by Shooter63 »
Hi all,
I've been offered a quaife type 9 all alloy gearbox, it's the model with synco and straight cut gears, the ratios seem OK, what do you guys think of it as a box for road work?
Re: Quaife gearbox views
I have a Quaife from a racing Caterham . Close ratios , straight cut , a nice box. My 1st gear is 2.04 so if you have a high geared diff/3.89 it'll be annoying in traffic , otherwise it's great . Find out it's ratios . Nice that it's all ally though . Mine is uprated lubrication wise plus roller needle bearings , all done by Brian Hill in KENT.
2.04
1.54
1.24
1.0
0.91 not certain of this one :?:
diff 4.4
kevp
Post by kevp »
Why question - you need it! Especially as its alloy. You can always sell it on if you change your mind. :lol:
I have a Tran x straight cut. Dont know the ratios but changing gear is easier on the down shift. Noisy as you like though.
Shooter63
Post by Shooter63 »
The ratios are
2.04
1.54
1.24
1.1
.87
Needle rollers, steel baulk rings, lever and knob, alloy main case and lid
The 5th gear ratio at 0.87 will be a nice cruiser on the road . What's your diff ratio ? Sounds a nice box , mine's not ally .
Shooter63
Post by Shooter63 »
stylussprinter wrote:The 5th gear ratio at 0.87 will be a nice cruiser on the road . What's your diff ratio ? Sounds a nice box , mine's not ally .
I'm running a 3.89 ratio, but as I normally start off in 2nd with a bit of clutch slip, I think it will be ok, I've asked a few more questions, ie input shaft length, bill of sale ( it's brand new) etc, so we will see.
Ps thanks for the photos, they have given me a good guide on what's required in the cutting dept.
Ps thanks for the photos, they have given me a good guide on what's required in the cutting dept.[/quote
With a 3.89 and a 1st gear ratio of 2.04 , it'll do damn near 70mph so why start in 2nd :?:
Shooter63
Post by Shooter63 »
Slight confusion, with my present box ( std 2ltr type 9) I pull of in 2nd, 1st is just too low,
se7ensport
Post by se7ensport »
Did you take the box? Interested to know if its a straight swap out. I'm after something similar, just waiting for one to come up.
Shooter63
Post by Shooter63 »
se7ensport wrote:Did you take the box? Interested to know if its a straight swap out. I'm after something similar, just waiting for one to come up.
No doubt you have heard of the saying, if it seems too good it normally is, well I'm pretty sure this is the case with the quaife. I found the ad on line, sent an email to ask the normal , still available etc received an email back confirming, when I asked if it was a short or long input shaft I got a vague response, this is when I got very suspicious, I asked on another forum if anybody was in the area, and if they would be willing to go and see the box, a guy volunteered, so I asked for a time, no response, after a few non answered emails I thought I would get sneaky, I got someone else to email, same thing all good up until you ask to see the box then nothing.
Good job you were suspicious :!:
se7ensport
That's a shame, glad to hear you didn't get conned; sounds like we are both still looking. A 6 speed Caterham box came up on Locostbuilders.co.uk yesterday, listed about 17.00, by the time I logged on at 20.00 it had sold!
Shooter63
Post by Shooter63 »
I phoned spc the other day, he can sort me out ok,
