Do I have to upgrade brake discs with M1144 pads?
- se7ensport
I've just got myself some M1144 pads, I've got new discs already but they are plain vented ones, do i need to get grooved or drilled?
If so can you recommend a cheap source?
Re: Do I have to upgrade brake discs with M1144 pads?
se7ensport wrote:I've just got myself some M1144 pads, I've got new discs already but they are plain vented ones, do i need to get grooved or drilled?
Alex, the discs you have will be fine, if you want to upgrade your discs go for grooved NOT drilled, as drilled discs have a tendancy to crack
- se7ensport
- se7ensport
- se7ensport
Re: M1144
they are if you stalk ebay and find a set for £9!!!!!!! they only had one set to fit sierra calipers otherwise I'd have bought more, but they do have othersCerberus wrote:I've just looked at the price of these, and f##k me, are they worth it![]()
http://search.ebay.co.uk/search/search. ... p=1&fsoo=1
