Shock Bolt Centres
Shock Bolt Centres
Does anyone know what the distance is between the bolt centres on the front and rear shocks? Were putting the car down on its wheels and want to put some angle iron in, in place of the shocks for the moment.
Re: Shock Bolt Centres
Pete&Matt wrote:Does anyone know what the distance is between the bolt centres on the front and rear shocks? Were putting the car down on its wheels and want to put some angle iron in, in place of the shocks for the moment.
Really depends on your set - up / shock length / spring length . Over the years different ones have become standard. As a guide , I would measure your shocks open then closed length --- take the midway position as an approximate length just for fixed rods. Rear's could be different , probably longer .
Rob,
we dont have any shocks, hence, cant do as suggested. Ill contact Tim and see if he has the measurment.
hearbear
Post by hearbear »
Pete&Matt wrote:Rob,
I will try to measure mine on wednesday when I get home it should give you any idea if you haven't got a hold of Tim.
cheers George
ok, thanks
Cerberus
Shocks
Post by Cerberus »
My centre's are as follows Front-306mm - Rear-356mm(15inch rear shocks)
Phil :D
thanks for the reply! can get the engine in at the weekend now!
lengths ?
Pete&Matt wrote:thanks for the reply! can get the engine in at the weekend now!
Pete , you didn't say whether your rear arms trailing are straight or concave or what Phils(cerberus) are. This will put it out if yours/his aren't the same -- just a thought :roll: Rob.
Rob, ours are concave/bent type.
LINKS ?
Pete&Matt wrote:Rob, ours are concave/bent type.
That's o.k. then because Phil's is Nathans converted classic and he changed the back end to concave links so longer shocks. Sorted :wink:
out of intrest, what was the reason for putting bent arms on instead of the original straight type?
reason ?
To lower the car while still allowing even longer shock travel for better /grip/handling/roadholding.
I lowered mine before having concave trailing arms which involved shorter shocks/springs to avoid running out of piston travel .If I'd not done that then there would be NO SUSPENSION , ultimately bending arms etc. This of course made my car very sensitive so eventually converted to SSC's concave arms once Tim had developed them . They're all concave since then with great advantage for kit buyers after that.
hearbear
Post by hearbear »
Mine are 285mm front and approx 330mm on the rears (difficult to get into in the Garage) the rears are on to the bent arms. I am building the classic model which is not finished yet including the suspension setup.
Cheers George
