Quick queston for anyone out there with a live axle.
Where's the best position for mounting the brake lines. I've got rear discs so there is a flexible hose from the caliper, but i can't figure out where to run the lines.
Thanks for any help, any pics would be good also
Jason
Brake lines, live axle
Re: Brake lines, live axle
If you hang on a minute i'll go and take someJaysun370 wrote:Quick queston for anyone out there with a live axle.
Jason
I didn't build mine, i've just taken apart a perfectly road worhty car and ruined it (feels like that at the moment) but it should be worth it when its finished here is a better photo of where it feeds in and joins up to the rear brake linesJaysun370 wrote:Hi Phil,
Ta for the pics. won't be any worse than my efforts i can assure you
Where did you tee into the lines? I was going to go for midway and use a flexible hose for the connection to the front to rear line. Sound about right??
cheers
Jason
Hope this is clearer for you.
