capri rear brakes
capri rear brakes
Free to good home
Tidy set of capri rear drums with back plates, shoes, braided line and cylinders - i'm clearing clutter and can see the car again
Drop me an email if your want them
So yellow, is t right or wrong??
drums
Anton , are Capri drums an exact fit onto Escort M2 English axle ???
Drum Sizes
What size are the standard escort drums i've just looked at mine and they are 9.5" could they be capri or standard if they are capri theres your answer.
Right i'm pretty sure they're 9" drums but they're different to the ones that go on an escorts i guess this is because of the axle. i think an escort runs an english axle and the bigger engine crapi runs the atlas. Whether these would do as an upgrade i'm unsure i suspect it depends on the bolt pattern onto the axle and whether the deth of the halfshafts from bearings to mating face will be too small.
Darn complicated these simple things!
9 ''
Well mine are 9 inch on my English axle and I know 8's and 9's are interchangable but wasn't sure that 9's were from Capri's . I assumed they were an upgrade from an RS2000. I'd like them Anton but if they turn out to be different fitting wise someone else can have them for their Atlas axle at any time.
Re: 9 ''
Rob my dear fellow if you want them they're yours - if they don't fit then someone else can have dib's on them from youstylussprinter wrote:Well mine are 9 inch on my English axle and I know 8's and 9's are interchangable but wasn't sure that 9's were from Capri's . I assumed they were an upgrade from an RS2000. I'd like them Anton but if they turn out to be different fitting wise someone else can have them for their Atlas axle at any time.
9 inch
Great , thanks Anton.
