Stylus radiator?
Stylus radiator?
Doesn anyone know wich radiator is needed for the stylus. It's something I completely forgot about untill I saw the car yesterday evening.
BTW, gardeshed is up and filled/cleared garage, so can commence with the engine and move the car in when engine is ready.
Anyone perhaps have a set of zetec e engine mounts lying around?
Re: Stylus radiator?
I have a set of pinto mounts and mounting rubbers if they are any use at all.Werner Van Loock wrote:Anyone perhaps have a set of zetec e engine mounts lying around?
If you are running a zetec then a PASSAT DEISEL is a good radiator because both inlet and outlet are on the left -- very convenient. My engine's run beautifully with that rad' and no problems also very cheapWerner Van Loock wrote:Doesn anyone know wich radiator is needed for the stylus. It's something I completely forgot about untill I saw the car yesterday evening.
The problem for me is that Tim is too far away from belgium to do the trip in 1 day and if I have to stay over night it will cost me too much (boat/train is also more expensive if staying longer then 24hrs)Pete&Matt wrote:Tim can supply the rad along with a fan for a good price
Up to Rob's is about the limit.
Werner, don't you have any vehicle recyclers in Belgium i know they have them in Holland (or at least they used too)Werner Van Loock wrote:The problem for me is that Tim is too far away from belgium to do the trip in 1 day and if I have to stay over night it will cost me too much (boat/train is also more expensive if staying longer then 24hrs)Pete&Matt wrote:Tim can supply the rad along with a fan for a good price
remember !
Also remember it's alloy with plastic ends so very light Rob.(got mine from DIAL A RAD )Pete&Matt wrote:the rad and fan isnt very heavy and so the postage wont be too much!
Ill remember the passat diesel!
The one i have looks very similar to somthing from a fiesta, ford type rad
which way ?
Pete,Pete&Matt wrote:is there a certain way they have to go? we have our pipes and sensor on the right hand side as this is the only way we could get it to fit and our outlets are that side too!
What I said only refers to fitting a zetec as both engine water entrance/exit 's are on the left side of the engine.So the PASSAT DEISEL's perfect for it.
polo
I used one of those when I built the car but when replacing it after an 'incident' was told the P.Deisel had more cooling capacityBikenuts wrote:I got a Polo rad of E-bay for £10 it's got both outlets on the same side - probably very similar to the Passat one. It's got no filler cap or breather so could be mounted ether way up.
which one ?
I'll go through my invoices back 3 years and maybe find itWerner Van Loock wrote:Rob, do you know from what year/period/model the passat diesel rad needs to be?
maybe you can identify it by looks?
http://cgi.benl.ebay.be/Volkswagen-Pass ... dZViewItem
and
http://cgi.benl.ebay.be/PASSAT-MK3-1-6T ... otohosting
and
