Stylus radiator?
Werner Van Loock
Stylus radiator?
Post by Werner Van Loock »
Doesn anyone know wich radiator is needed for the stylus. It's something I completely forgot about untill I saw the car yesterday evening.
BTW, gardeshed is up and filled/cleared garage, so can commence with the engine and move the car in when engine is ready.
Anyone perhaps have a set of zetec e engine mounts lying around?
Tim can supply the rad along with a fan for a good price
hearbear
Re: Stylus radiator?
Post by hearbear »
Werner Van Loock wrote:Anyone perhaps have a set of zetec e engine mounts lying around?
I have a set of pinto mounts and mounting rubbers if they are any use at all.
Werner Van Loock wrote:Doesn anyone know wich radiator is needed for the stylus. It's something I completely forgot about untill I saw the car yesterday evening.
If you are running a zetec then a PASSAT DEISEL is a good radiator because both inlet and outlet are on the left -- very convenient. My engine's run beautifully with that rad' and no problems also very cheap :!:
Werner Van Loock
Pete&Matt wrote:Tim can supply the rad along with a fan for a good price
The problem for me is that Tim is too far away from belgium to do the trip in 1 day and if I have to stay over night it will cost me too much (boat/train is also more expensive if staying longer then 24hrs)
Up to Rob's is about the limit.
Cerberus
Post by Cerberus »
Werner, don't you have any vehicle recyclers in Belgium i know they have them in Holland (or at least they used too)
Phil :D
the rad and fan isnt very heavy and so the postage wont be too much!
Ill remember the passat diesel!
The one i have looks very similar to somthing from a fiesta, ford type rad
remember !
Pete&Matt wrote:the rad and fan isnt very heavy and so the postage wont be too much!
Also remember it's alloy with plastic ends so very light :D Rob.(got mine from DIAL A RAD :wink: )
is there a certain way they have to go? we have our pipes and sensor on the right hand side as this is the only way we could get it to fit and our outlets are that side too!
which way ?
Pete&Matt wrote:is there a certain way they have to go? we have our pipes and sensor on the right hand side as this is the only way we could get it to fit and our outlets are that side too!
Pete,
What I said only refers to fitting a zetec as both engine water entrance/exit 's are on the left side of the engine.So the PASSAT DEISEL's perfect for it.
Bikenuts
Post by Bikenuts »
I got a Polo rad of E-bay for £10 it's got both outlets on the same side - probably very similar to the Passat one. It's got no filler cap or breather so could be mounted ether way up.
polo
Bikenuts wrote:I got a Polo rad of E-bay for £10 it's got both outlets on the same side - probably very similar to the Passat one. It's got no filler cap or breather so could be mounted ether way up.
I used one of those when I built the car but when replacing it after an 'incident' was told the P.Deisel had more cooling capacity :wink:
Werner Van Loock
Rob, do you know from what year/period/model the passat diesel rad needs to be?
which one ?
Werner Van Loock wrote:Rob, do you know from what year/period/model the passat diesel rad needs to be?
I'll go through my invoices back 3 years and maybe find it :roll:
Werner Van Loock
