As above, what have you got and how much do you want? Would prefer AVO, GAZ or protech.
Cash waiting.
Pair of shocks wanted either 10 or 11 inch x 2.25
- se7ensport
length
Is that open length ? because 10 inch will see you with 6 inch springs and unless you've got rocker arms specially angled , then your tyres will be dissapeared up the wheel arches. If for the rear ---- definately a no no
11 inch open is as far as you can go up front . You will need 7 inch springs and due to the lowered stance , to keep you off the arches when turning under pressure , stiffer springs . You may already have stiffer than the original standard
Finally , 11 inch shocks are on the lower limit of the required piston travel unless going to more expensive shocks/greater travel for given open length.
I've had several years dabbling with many shock/spring/lbs lengths so wouldn't want to see you buy only to give you more hastle
Andy Bailey has a pair of 12 inch AVO's spare ---- what length are you on now
Rob --- not trying to teach grandma to suck etc
- se7ensport
Cheers Rob, appreciate the info as always.
At the moment I have 13 rear and 12 front open length (I 'm not going lower, just looking for more travel at current hight- current chasis hight is 148mm front and 168mm at the rear), after some careful measuring with the car loaded I have found that the rear sits comfortably under 12 inches (probably closer to 11-11.5) - my plan is to move the 12 to the back as it will actually increase piston travel as they have a shorter closed length by 1/2 an inch, it’s the same story up front, I think 11 would be ideal, although would consider 10's as I can raise the bottom mounts with a bracket spacer I can make up.
I'm running 180lb rear (9 inch) and 240lb front (7 inch).
I can wind all spring platforms down so that the car is resting on the bumpstops without the wheels binding anywhere and it looks as though they could go another 1/2 in lower without causing issues, my current ride hight means I hit the bump stops occasionally.
I would consider getting a pair of 12's for the rear to test my theory, but it would mean I'd still need to get some 11's for the front in the future, that said it's the rear travel that needs increasing the most..... do you know how much Andy wants for them?
avo shocks
Hi Alex
just upgraded my rear suspension, to Tim's latest spec , so I've a pair of 12/85 avo 2.25 dia with 8inch 200lb springs to sell
how's eighty quid, I'm in Woking Surrey Tel No 01483 473437
cheers Andy
cheers Andy
- se7ensport
Don't know what he'll want for them , try him on PMse7ensport wrote:Cheers Rob, appreciate the info as always.
Have you got long travel rear arms ?
Rob.(sorry it was a long time replying but been working on the green car while it's NOT raining !)
- se7ensport
Rob, wish I could work on the car during the day!
I'm looking for about 140 at the front as I have a few speed bumps to contend with
and 160 at the rear.
I don't have the long arms and think this is about as low as I can go- hence using the 12 inch which are 8.5 closed instead of 9 on the 13's I'm currently running.
The other bonus I can think of in using shorter shocks is reduced roll at the same ride hight, as the inside of the car can only jack up to the length of the shock fully extended.
Roll ?
Roll will not be influenced by shock length . Roll resistance is dealt with mostly on the front and works diagonally . So turning fast RIGHT will be supported by the front left spring/lbs and bump setting. Also rebound at the rear RIGHT . Then the opposite when turning fast LEFT.se7ensport wrote:Rob, wish I could work on the car during the day!
I'm looking for about 140 at the front as I have a few speed bumps to contend withand 160 at the rear.
If you really want to control roll then fit the front anti-roll bar BUT disconnect one side in the wet
