Like you work Rosscorossco61 wrote:Hi all, still watching altho not doing much these days. Too many other irons in the fire !!
I see that Matt needs info on Intercooler placement.
Photo included with my install onto the Nissan CA18DET and a redesigned front mount frame.
Both the Radiator & the Intercooler are rubber mounted to the frame, in compression, not tension.
Air inlet to the Turbo will come over the Turbo to Int/cooler pipe, then turn to the center & into a Pod Filter,
mounted to the new frame. There is 8" clearance to the front body oval air intake from the frame.
NO Body Modding required !!!
Rossco
![Razz :P](./images/smilies/icon_razz.gif)
I'm retaining the original cheapo intercooler for now, which is considerably smaller than yours !
The throttle body outlet is also at the firewall end, so the pipe routes & lengths to the front end wouldn't be pretty.
I'll be ducting air through a NACA on the bonnet into an airbox, with the cooler mounted at an angle behind the passenger front wheel, exiting into the sill.
Not ideal.. but it should work.
