Got my freshly built black top remapped today, 198bhp at the wheels (about 240 flywheel bhp).
Paul worked his magic - new cams, ported head, pocketed pistons, rod bolts, lightened flywheel etc.
I was hoping for 220 so imagine my glee!
woohoo - thanks Mr Dunnell
Re: woohoo - thanks Mr Dunnell
May I ask about the £s ? Probably way over my budget.
That's a fantastic at the wheels bhp Mine doesn't make that , although I wasn't convinced in NORTHAMPTON MOTORSPORT's rollers showing 157bhp from my engine which Paul's dyno showed 243bhp at 8300 rpm flywheel . I don't run 243bhp due to no drysump so it's rev-cut at 7750rpm gives 231bhp .
You will love it's torque
I've only driven it in the damp so far, but quite looking forward to opening it up!stylussprinter wrote:That's a fantastic at the wheels bhp Mine doesn't make that , although I wasn't convinced in NORTHAMPTON MOTORSPORT's rollers showing 157bhp from my engine which Paul's dyno showed 243bhp at 8300 rpm flywheel . I don't run 243bhp due to no drysump so it's rev-cut at 7750rpm gives 231bhp .
Cost? With all the goodies like flywheel, clutch, alternator and bracketry, inlet manifold, verniers etc it came to a little under £3k.
there are plenty of cheaper ways to do it, but you know with Dunnell that it will work out of the box.
I'm actually a bit worried whether the rods are up to the power?
thats a really high peak power, if you're limiting at 7750 (I'm planning the same after a bit more running in, currently limited to 7600) then maybe you should swap cams? These are supposed to peak at 7600 i think.stylussprinter wrote:That's a fantastic at the wheels bhp Mine doesn't make that , although I wasn't convinced in NORTHAMPTON MOTORSPORT's rollers showing 157bhp from my engine which Paul's dyno showed 243bhp at 8300 rpm flywheel . I don't run 243bhp due to no drysump so it's rev-cut at 7750rpm gives 231bhp .
other point is, i really don't know how accurate the rolling road was, they should really calibrate them shouldn't they?!
