Can anyone help
Stylus related discussions
hearbear
Can anyone help
Post by hearbear »
Is there anyone with a SSC roll bar fitted who could measure from the floor behind the seat to the cross bar where the harness bolts go in and how far a part the 2 holes are on each side as may have the chance of of getting a couple of alluminum seats cut and would need to add to the drawing the harness holes. No chance of seeing mine for while.
Re: Can anyone help
I'll measure up tomorrow for you George ok
Re: Can anyone help
Hi George
Are you thinking vertical rollbar with rear stays (like Rob's), or the later leaning forward type, with forward stays (like mine & now converted to full cage) ?
hearbear
Re: Can anyone help
Post by hearbear »
MattD wrote:Hi George
Yes the vertical with the rear stays its the one nissan man had.
Re: Can anyone help
Right George , I hope these are what you're after as my bar was made by Tim for me with the dimentions I asked for . All bars mount from the same chassis top plate though so should be ok. From the seatback ledge to the top of the crossbar is 10ins . The threaded inserts are mounted on top of the crossbar , starting 3.25 ins from the upright to insert centre and 7.25 ins centres/ apart . They lean around 15 to 20 degrees towards the front of the car . The top of the roll bar is 23.75 ins from the ledge/ behind seatbacks and the uprights are 35 ins apart internal measurement. I took photos before realising that I couldn't add them from the PC as it's still defunct . I get browser access via my iPhone only . Hope this helps mate :roll:
hearbear
Re: Can anyone help
Post by hearbear »
Cheers for that Rob could you measere from the floor to the ledge behind the seat where you took your measurements from.
Re: Can anyone help
Sorry , didn't realise you'd need that . Obviously the steel seatpan back is slanted a little but the measurement from floor to ledge is 16ins . :wink: My seatback goes well above the crossbar to catch my helmet so the seat has two large holes for the harnesses to pass through , level with my shoulders when seated.
hearbear
Re: Can anyone help
Post by hearbear »
Many thanks Rob for that I will just finish the CAD drawings and hope for the best :D
