1st one looks correct from the drawing. Top left is HOT from engine plus a bleed which I bung up. Bottom left is COOLED to the engine water pump. Measure between the A frame on the front of your chassis though. This radiator picture shows it's 632mm wide so you need to be sure it'll go in.
2nd secondhand picture looks wrong. Rob.
Stylus radiator?
by looks ?
