OOOPs
understeer ?
Then you've either got too much camber or not enough wedge. If you have a lot of camber , say 3 degrees , then you will get understeer unless you enter a LOT faster than previously to get the benefit of the grip to be found when the car lifts , making the tyre level with the tarmac again.
se7ensport
Post by se7ensport »
Did sorting the toe and camber reduce the odd feeling at speed?
Cerberus
Post by Cerberus »
se7ensport wrote:Did sorting the toe and camber reduce the odd feeling at speed?
What i've guessed at has resulted in an amazing transformation, it stays in a straight line under very heavy braking instead of the rear end trying to swap with the front and under throttle it doesn't weave across the road like i have rugby balls for wheels, Wednesday we will go out again if you want and have another vehicle swap.
:D
Cerberus
Re: understeer ?
Post by Cerberus »
stylussprinter wrote:Then you've either got too much camber or not enough wedge. If you have a lot of camber , say 3 degrees , then you will get understeer unless you enter a LOT faster than previously to get the benefit of the grip to be found when the car lifts , making the tyre level with the tarmac again.
Rob, i have adjusted the camber as advised by Tim but only roughly i will buy a gauge soon as i want to sort that before Llandow as i don't want to waste too much track time, also i need to set toe which has improved BUT doing it by eye doesn't cut the mustard :wink: as for wedge i'm running 22mm
:D
