New Fuel Tank
Werner Van Loock
Re: New Fuel Tank
Post by Werner Van Loock »
se7ensport wrote:Thanks the info Rob, due to fitting issues caused by the De-Dion I have to exit out of the side of the cup at the bottom rather than straight out of the bottom, outlet is 12mm and I plan to push a number of foam fuel cubes up it to reduce any chance of starvation.
I'm really struggling to find a sensibly priced 12mm pre-filter as £50 seems a joke for the Sytec Bullet one, I have found one for about £22 delivered that seems pretty similar http://cgi.ebay.co.uk/SYTEC-FUEL-INJECT ... .m14.l1318
anything else out there worth looking at?
Found this on locostbuilders, but been unable to locate one yet. But haven't been to a dealer yet.
http://www.locostbuilders.co.uk/viewthr ... ssage=none
audi 12mm pre filter
Re: New Fuel Tank
This is how mine ended up.
I bought the bullet filter & had the guys change the pipe fitting to what I wanted.
10mm outlet on tank cup to 10mm bullet inlet >> 12mm outlet into 12mm Pump.
8mm feed, 6mm return.
You got it in one on the way the tank base is cut & the cup welded on.
The hole in the base was formed into an edge like a sink plug hole.
All worked spot-on since its been fitted.
se7ensport
Re: New Fuel Tank
Post by se7ensport »
Werner - there doesn't appear to be an Audi dealership in the UK that has the fuel filter any more :(
Matt - thanks for the info and neat looking install. Turns out I'm using the same company to build my tank, due with me monday.... then its injection time.
