But I will be getting new engine mounts welded by someone that can weld
Sorry Phil , I saw the yellow car (norma) and thought I was replying to you --------- good job I'm retiring ayeCerberus wrote:Rob, your memory is not working, my car was the one Nathan converted![]()
stylussprinter wrote:Sorry Phil , I saw the yellow car (norma) and thought I was replying to you --------- good job I'm retiring ayeCerberus wrote:Rob, your memory is not working, my car was the one Nathan converted![]()
Well, I'm using the escort setup, yours is the sierra setup, so it's a bit different, but the bracket might work.spidermike wrote:Regarding the brake lines.
.just went stright past with my hoses![]()
check out the uprights ..looked good 3yrs ago when i put them on
I don't knowWerner Van Loock wrote:Rob,
Mine also have the bottom pins, and i've used a long piece of metal with 2 holes drilled in and bent around the support frame, so I will probably also connect the top to the D-shape fiberglass then.
The reason it's already mounted is that i want to see the engine running and perhaps driving the car before i start with the body.
