mikeb wrote:I think that a little section should be attached from the lower dash board mounting bar to the top of the transmission tunnel.
Yes, tricky bit of welding though - I might just bond and rivet some angle between the two.
Weekend update:
Thanks to MattD and NevP, I have managed to get hold of a 'new' bonnet panel. Whilst it needs a bit of work, hopefully it will be less than the one I already have with a great big hole in the middle. Although it has sagged a little at the windscreen end, I'll put some weight on it and see if it wants to go back.
I've also picked up a set of Lasers with some rock hard A048 wets on, for pushing the chassis around if needed.
First job was to extract the pedal box. This put up more opposition than I had anticipated, but I won the battle in the end!
Next it was time to attack the chassis on the drivers side. For trial purposes I've cut the upright at the end of the tunnel and bent it so that it is vertical. I also cut around the footwell side panel to bend that out of the way to line up (roughly) with the new upright position. (Looks odd in some of the photos, but it is vertical)
I tried the gearbox back in at that point, and stared at it for a while... and decided to keep cutting. I cut the side of the footwell off entirely and trimmed back the front panel to roughly vertical, as this was a bit close to the bellhousing. I also cut out the diagonal which goes towards the front of the chassis, which will be re-fitted and re-aligned once the footwell is rebuilt. I also cut and bent the longitudonal tube on the top of the tunnel on the drivers side to see how it will look aligned with the new upright. Popped the gearbox back in for more ponderings.
My shiny new seats should be arriving this evening, so I'll have another sit in it and see how it feels. I might be able to decide what I am going to do with the pedals then... I have an OBP pedal box, but might be changing my mind over whether to use it or not, it would at least need some modifying to fit in the footwell.
