Used GAZ dampers for sale. Came with my car but now using new longer dampers due to changing to the dipped arms
Marked as 130/090 B12 B03 Which I believe mean 13 inch open 9 inch closed. For 2.25 springs.
£SOLD
2 sets of used springs that were on the above dampers, both in good condition.
9inch long 2.25inner diameter 200lbs - £30 collected
9inch long 2.25inner diameter 250lbs - £30 collected
Standard Blacktop Zetec Sump without metal pickup from a 2000 year Zetec. Ideal for getting chopped and shortened.
£20 collected
£SOLD Pickup
Located in Chesterfield, Derbyshire
FS: GAZ dampers, Springs and Zetec Sump
Re: FS: GAZ dampers, Springs and Zetec Sump
Dampers and Pickup Sold.
Both set of 9" springs still available (200lb and 250lb) as is the sump.
