Zetec coil pack
Posted: Tue Jun 18, 2013 10:05 pm
Pretty sure the misfire is a result of the coil pack giving up. The one fitted to my car is part number 928F-12024-BE which appears to be specifically for the Escort XR3i which figures as I have a 1992 1.8L engine.
That particular part number is quite obscure but from what I've read any coil pack for an early Zetec (with the clip on type leads) will do. Is that correct? Is there anything (aside from needing to change the leads) stopping me from using a later type coil pack with the push on terminals?
Last question, anyone had any experience of the cheapo pattern parts? The options are around £25 for a pattern part but I'm always sceptical about the quality. The expensive option is the Accel 140018 at almost £60 delivered. Ouch. Genuine ones don't seem to be available, at least not without remortgaging everything I own.
