NEW SSC Front anti - rollbar
Put your parts for sale here
Hello guys ,
Just a short notice to tell you that Tim has fixed a price for this developement , now that it's done some track time plus a lot of road mileage.
£150-00p inclusive of VAT .
Easy retro fit - two holes to drill through the front triangulated chassis - the rest is all bolted.
Any bar spec' to order - thickness.
Three adjustment levels.
All links are high quality rod ends.
Supplied black powder coated.
Big advantage apart from the obvious one is -------- there's nothing to remove in order to fit it , unlike the usual bar that would normally run the width of the car and attach to lower wishbones , which would need brackets welded to them so need to come off. Also the radiator is in the way to be able to drill the front chassis rail to attach polys/bar.
That's why I've not done it till now :roll:
Rob. 8)
se7ensport
Post by se7ensport »
Indeed, saw yours and had a chat with Tim a couple of weeks ago.... looks at least 3 paypackets/months away at the moment, rolling road this month, hood next month and roll bar next then antiroll bar
Werner Van Loock
Post by Werner Van Loock »
Anyone got pictures of it? Then I could get it on the site.
SSC front anti-rollbar pic's
I tried moving the pic's from suspension etc section but it simply moved them here but not in this thread ----- so just took some more pic's and put straight on this thread.
Rob. :) Image
