I digress ----- so yesterday I bought cable and connectors to fit some Anderson jumpstart's into the cockpit on the passenger tunnel. I didn't connect direct from the battery. Positive went to the LeMans cut off switch in the dash then the negative I connected to a bolt that was holding the battery tray to the passenger footwell . Obviously I removed the bolt completely to grind the steel footwell back to bright steel around the bolthole. It's not yet fixed to the tunnel , I'll sort that another day . The difficult bit was crimping the very strong connectors around the battery cable , as I wasn't prepared to spend £50 for proper heavy cable crimping tool. Crushing them using only the corner of the bench vice worked ok but then the connector was deformed wider which made pushing the cable plus connector into the Anderson's was quite a fiddle ----- anyway job done now apart from a handle which I've ordered online , then I'll fit it to the tunnel.
My roadstart is always live without an off switch so the croc clips used to each have a housing BUT now it just has the one Anderson connector which I can drop into one of the housings.
So now I'll be able to connect the roadstart before attempting to start the engine without getting out of the drivers seat , undoing the 6 point bonnet then back in the car to start ---- out the car to shut the bonnet --- back in the car etc etc
You can imagine the scene
