Rad connections
Rad connections
Has anyone had issues getting a bottom rad hose to fit? The rad I have has the top and bottom connections on the same side. The distance between the end of the stump and the steering rack boot is 45mm! At present I cannot get a hose with a 90° bend to fit! Even if I welded up a pipe work assembly with a mitre joint, it would only leave me around 5mm to get a hose and clip on! The stumps are 32mm diameter.
thanks
