Arrrgh!!!!!!!!
Posted: Fri Mar 25, 2016 5:00 pm
I took the car down to get the camber set last weekend, the shop said that the bottom joints were seized solid, so that was aborted. I ordered up so new joints, and set about what I thought would be a git of a job, I decided to take the whole A arm off as I could attack it easier etc. the 1st one was a bit tight but came out with a squirt of plusgas and a whack on the end of the joint to loosen the thread. Out and back in within 45mins ( good stuff me thinks) took the second one out, and wehey no problem, but the sucker punch was coming, a sodding l/h rod end in a r/h box luckily the old rod end was ok so I've put it back until the shop can order me the correct one.
The moral of this storey, check the rod ends in the box, not just the box part number.
