fuel tank
As the title says
ianminki
fuel tank
Post by ianminki »
hi all
not had a post for some time but looking for a bit of help regarding fuel tank . At the moment I have a mg miget fuel tank fitted but wuold like to change to a ally tank that is baffled as the one have is ready for changing . can anybody recommend a company that do one for the stylus pls. the other thing I have been up to is fitting a x flow engine in place of the bike engine to witch I have had a lot of problems with regarding the rebuild of the engine . I took the engine to a so called engine specialist in Scunthorpe to have the engine re bored and the crank reground and all other jobs that needed sorting but was not done properly . just some of thing that where not right.... re bore not finished crank not done + plus bent wrong size piston rings engine not cleaned out after re bore and so on . I do have a report from an other engine specialist that I took engine to and he has done a grate job been out in the stylus and it now sound grate . so at the moment I am looking to trying to get some money back from the first one that is no good to man or beast .. regards ian
Re: fuel tank
ianminki wrote:hi all
Ian , no company makes a specific ally baffled tank for the Stylus but that's not a problem . Remove the one you have then simply measure up the length x width x height that you want AND can be squeezed in THEN get one made up . A cardboard shape/sized test blank is a good idea .
