Protech's
Posted: Mon Nov 13, 2006 8:33 pm
by Cerberus
Anybody running protech suspension on their stylus?, i need to know how to get to the third damper range as mentioned in car set up, i thought i'd ask on here first to save taking up Tims valuable time.
Re: Protech's
Posted: Mon Nov 13, 2006 9:55 pm
Cerberus wrote:Anybody running protech suspension on their stylus?, i need to know how to get to the third damper range as mentioned in car set up, i thought i'd ask on here first to save taking up Tims valuable time.
Phil , I think it's covered in the main clubstylus site under build or set up ? All sorts plus Protech specifically.
Re: Protech's
Posted: Mon Nov 13, 2006 10:08 pm
by Cerberus
Rob, i checked there before posting, it says contact SSC, if i don't here anything on here then thats what i'll have to do.
Re: Protech's
Posted: Mon Nov 13, 2006 10:36 pm
Cerberus wrote:Phil , I think it's covered in the main clubstylus site under build or set up ? All sorts plus Protech specifically.
Phil , I've just searched on google and found B& R special tuning. They have instructions on altering protech levels of damping.
Posted: Mon Nov 13, 2006 10:49 pm
You turn the adjuster up to the max you then loosen the grub screw holding the knurled adjuster you the turn the adjuster back to the min position while holding the shaft to stop it turning back. Tighten the grub screw and then adjust to the max and the repeat the slacking and returning to the min again you are then in the third adjustment range. You have to be careful when returning the adjuster to the min poss in case the spring and ball come out (don't let the adjuster move up the shaft) and disappear into orbit. This was how Tim told me to do it.
Hope this helps George
Posted: Mon Nov 13, 2006 10:55 pm
by Cerberus
hearbear wrote:You turn the adjuster up to the max you then loosen the grub screw holding the knurled adjuster you the turn the adjuster back to the min position while holding the shaft to stop it turning back. Tighten the grub screw and then adjust to the max and the repeat the slacking and returning to the min again you are then in the third adjustment range. You have to be careful when returning the adjuster to the min poss in case the spring and ball come out (don't let the adjuster move up the shaft) and disappear into orbit. This was how Tim told me to do it.
Thats excellent George thanks, by the way howmany ranges of adjustment are there?
Posted: Mon Nov 13, 2006 10:58 pm
Cerberus wrote:hearbear wrote:You turn the adjuster up to the max you then loosen the grub screw holding the knurled adjuster you the turn the adjuster back to the min position while holding the shaft to stop it turning back. Tighten the grub screw and then adjust to the max and the repeat the slacking and returning to the min again you are then in the third adjustment range. You have to be careful when returning the adjuster to the min poss in case the spring and ball come out (don't let the adjuster move up the shaft) and disappear into orbit. This was how Tim told me to do it.
Sorry not sure
Re: Protech's
Posted: Tue Nov 14, 2006 10:38 pm
by Cerberus
stylussprinter wrote:Cerberus wrote:Phil , I think it's covered in the main clubstylus site under build or set up ? All sorts plus Protech specifically.
Rob, i didn't see this post last night
, after looking on here at set up i did a google search but could only find TVR & bike shocks, so after reading your post i did another search including B&R but still it comes back with nowt, i will do what george has said this weekend, and let you all know how i get on.
Thanks for your help
website of B and R
Posted: Wed Nov 15, 2006 10:02 am
Sorry , didn't give you the exact site details as I found it through browsing from another site.
http://www.brspecialtuning.co.uk
Re: website of B and R
Posted: Wed Nov 15, 2006 12:24 pm
Slightly differant way than I was told to do by Tim. As I still have this to do on my car I think I will do it the way decribed on the website.
Posted: Wed Nov 15, 2006 4:43 pm
by alecmartin19
there is a protech website that tells you how to set up all of the products they provide. the address is
http://www.protechshocks.co.uk
hope this is some help too!
i do try!
Posted: Wed Nov 15, 2006 7:45 pm
by Cerberus
Thanks Rob
Maybe i'm having a blonde moment here, doing it Tim's way, if you go up and down twice on the adjuster you know you are on the third range as it says you should be in the setup section on here, how do you know what range you are on doing it the other way?, it just says turn it half a turn clockwise to increase or anti clockwise to decrease, but how will that compare with Tim's settings, is it just trial and error? surely it will be spot on using Tims experience i know it seems more fiddley but he's the man that knows. or have i missed something
Posted: Wed Nov 15, 2006 10:34 pm
Thanks Rob
Seeing as I don't use Protech , you're best talking to Tim if the protech site doesn't make it clear to you. I have no personal experience of them.
Posted: Wed Nov 15, 2006 10:40 pm
by Cerberus
Thanks Rob
I'm off work tomorrow so it's off to wales.
