Page 1 of 2
Quiet week on the board....
Posted: Tue Feb 13, 2007 3:02 pm
by se7ensport
.....so what have you guys been up to stylus wise?
Over the last couple of week I have been:
Removing the runners from my seats to lower the seating position by about 1 1/2 inches, it makes a nice difference. I still need to drill a second set of holes so I can move the drivers seat forward so Amy can drive it.
Bought and fitted a fire extinguisher as I'm paranoid about how quick a glass car can burn!
Fitted new brake pads (M1144's), they make a real difference, so much so that I've had to stiffen the front shocks a couple of clicks due to "bobbing" under really hard braking…. Probably means they weren't set right to start with.
Fitted new water temp sender, so that the gauge reads accurately.
Bought some "cat crap" anti mist for my helmet (and biking goggles), it works pretty well, decided that it would be needed for Llandow (can't wait).
Met up with Phil (Cerberus) to talk cars etc….
quiet on this board
Posted: Tue Feb 13, 2007 4:37 pm
Posted: Tue Feb 13, 2007 5:49 pm
was supposed to be going to collect the shell for the car on saturday, but due to bad snow in Wales, has been put off to tommorow!
Posted: Wed Feb 14, 2007 1:08 am
Fitted new fuel tank.
Fitted new springs to trailer.
New Cambelt.
Drove up & down the drive.
Plugged lap top in, lambda sensor not working.
Discovered why body rubs on rear arches - springs to soft by far at rear. This also must be the reason why it jars me going over bumps.
Sent E mail to Tim about suspension upgrades.
Looking forward to next weekend.
Posted: Wed Feb 14, 2007 6:12 pm
by Cerberus
Still pumbing in the fuel system, nearly done now, ECU is still at Weber(so much for a 7 day turn around
) having the Lambda circuit removed and should be back next week
i have finished fabricating the exhaust( i hope it works
), made a complete f***k up of the battery tray so i will try again, i have purchased a set of 16"magnesium wheels weighng in at 5.5kgs each, they are 3kgs lighter per wheel than the old black ones, now its just the Wilwoods and alloy hubs and that should save my about 20-22kgs on unsprung weight
And i also need to cut a hole in my bonnet, so if anybody close to me has any fibreglass knowledge PM me.
Roll on Llandow
Posted: Wed Feb 14, 2007 9:32 pm
Posted: Wed Feb 14, 2007 10:52 pm
by se7ensport
I hope the extra space and order provides motivation
Posted: Thu Feb 15, 2007 1:31 pm
It is even more so after driving it out the garage and listening to the engine running
build motivation ?
Posted: Thu Feb 15, 2007 2:22 pm
The best motivation I found , apart from --- I want it finished
---- was a nice cheap little fan heater in the shed
I worked right through the winter months and enjoyed it. Some evenings , I didn't go to bed till 1-00 or 2-00 o'clock in the morning
YES , I know I'm bonkers but was just itching to get it done and if in the middle of a task that was going well , just didn't want to stop
Rob(having said that ; I'm not so keen now to fiddle with it at silly hours now it's built)
Posted: Fri Feb 16, 2007 8:54 pm
by MALKYVAL
I GOT MY PART BUILT CAR DOWN TO TIMS PREMISESTODAY.
I AM REALLY LOOKING FORWARD TO SEEING IT DONE
THANKS IN PARTICULAR TO ROB FOR HIS SUPPORT .MALCOLM
Posted: Sat Feb 17, 2007 4:38 pm
by alecmartin19
i'm spending my time off this week fixing my rear diff!
after the original escort diff giving up the ghost i've decided to put a quaife atb diff in there and a 4.4:1 ratio crownwheel and pinion.
when all the parts had arrived however, the threads on the brand new crownwheel were not in the right place and would not fit the diff so its had to go back and a new one made. apparently a bad batch.
after that it'll be a new gearbox for me i think just in time for the spring when i get back from working in Oman for a month!
i'll try and organise a gloucester/bristol meet then too!
wrong bits quality
Posted: Sat Feb 17, 2007 6:48 pm
That's a bugger Alec , never heard of that situation before -- still , it'll be great when it's sorted , box an all
Posted: Sat Feb 17, 2007 7:54 pm
by alecmartin19
apparently the crownwheel which i ordered from burton power was made wrong. they have got a bad batch so a lot of their stock has to go back too!
hopefully they'll get it sorted before i go away so i can put it all back together and try it out.
Posted: Tue Feb 20, 2007 3:09 pm
by Nissanman
Well - I'm carrying on with the wiring - it's nearly done
Posted: Sat Mar 17, 2007 10:59 pm
by se7ensport
Finished fitting a race head and Kent FR33 cam and took it out for a drive.....
The difference is SIGNIFICANT, I now need to get the timing and fueling sorted, looks like i'll be going for throttle bodies and new ignition as I'm fed up not being able to make the adjustments myself.
