Suspension bits !
Put your parts for sale here
Suspension bits !
A few stylus bits are floating around in my shed so here they are .
panhard rod £10
pair of front rocking arms £40
2 pairs of straight rear links £40 pair --- one still as new powder coated with bushes.
Last edited by stylussprinter on Tue May 15, 2007 9:06 am, edited 12 times in total.
hearbear
Post by hearbear »
wish you had put up the headlamps last weekend as I have just cut out and started to modify, mould for the 7" headlamps :( The summers coming but I am still hoping to SVA mid summer :D
cheers George
deleted
Last edited by stylussprinter on Fri Jan 19, 2007 2:19 pm, edited 2 times in total.
hearbear
Post by hearbear »
How much for all the front suspension parts and rear links. I have a neighbour who is about to build a locost from scratch and these may work for him.
Cheers George :D
deleted
Last edited by stylussprinter on Fri Jan 19, 2007 2:20 pm, edited 2 times in total.
hearbear
Post by hearbear »
Thanks Rob
I will pass it on this weekend and see if he is interested.
Cheers George
hearbear
Post by hearbear »
Saw him on Saturday and here had just bought a seirra on Friday night and is going to use instead of the escort setup. Thanks anyway Rob.
Cheers George
deleted
Last edited by stylussprinter on Fri Jan 19, 2007 2:21 pm, edited 2 times in total.
Roo4
Post by Roo4 »
Rob, Is the silencer still available, will it fit in the sill without cutting huge areas out of it??
regards
Iain
Chassis No.5 in rebuild. Iwill get there one day. 1.8 nissan turbo.
silencer
No , it wont fit in the sill . It's a 6'' diam' silencer with 2.75'' through pipe , repackable. If you fit one in the sill on a classic Stylus it would need to be 4'' diam' , to avoid fire risk. I didn't run a sill silencer until the power was upped/lowered the car further . In the RT the sill is larger.
Here's a pic' of my install , showing all the sill totally removed to the chassis plus up to 2'' from the door.Then the silencer is protruding out 1'' behond the body work. Rob.Image
Roo4
Post by Roo4 »
Thank Rob I want to keep it inside the bodywork.
regards
Iain
