Dating Engine for SVA
Posted: Sat Oct 13, 2007 1:31 pm
(Sorry - This should prob be under the SVA section but I'm hoping it will get a better response here.)
Anyway, I can't think how to go about this one -
History: I started with a 1.8 zetec from a scrapped orion (J-reg) but no paperwork available. Unfortunately the crankshaft seized after half-a-dozen revolutions the first time I started it (much waliing and nashing of teeth). Short story - the bearing shells disintegrated and I bought a new short motor (ie. only block crank and pistons). I've skimmed and re-used the head, valves and all other parts.
Current Problem: Prior to SVA I will need to prove the age of this contraption, and I do not know how to. The new short block has its own ID tag but no other paperwork and I can't understand the code stamped on the head. I can't get a response from any ford dealers or support websites I have contacted. How do I prove that this is a pre-cat engine, or do I have to redo everything and add a cat to the exhaust? What paperwork will satisfy SVA?
Specs: 1.8 Zetec 135PS, weber-alpha 'gold' injection system (complete), SSC provided exhaust and silencer (no cat). I have what I think is the chassis number and old engine number from the orion if this helps.
Any advice greatly appreciated.
Mark
Mark
