stylussprinter wrote:Great pic's . My god that's going to be a pig to work on though
-- no space to get at anything. What does the engine weigh
it's very far forward . Have you got P.Powell's original spring set of 180 fronts 130 rears
Nice alloy work , tank , intercooler
--- scary loom
Hi Rob, The pic's are taken with a Fiji S5500 -- 10x optical zoom Digital at a 2megapixel rate. Capable of 4 m/p but 2 seems to be sufficient.
"Pig to work on" Should not be too bad as it will finish up as not only a flip front but a full removable front. Note the steel lined rubber mounts at the bottom left & right front of the Rad/Intercooler mount frame.They are designed to accept steel pins hinged to the body front support panels.
Engine weight ?? Wish I knew !! It is an Iron Block & exhaust manifold, but with Alloy head & intake. Have tried several sources for info, so far, no results.
Engine "far forward". The front of the timing case is 6.5 inches behind the front chassis rail. The Nissan engine mounts sit on new Chassis mounts at the rear of the original mount positions. I assumed that was correct ??
"Spring sets", yes I have P.P original springs with AVO front shocks & GAZ rear units. -- From what I have read in this Forum, I will need to replace the springs. This should be easy -- we have a good Industrial Spring maker in Adelaide -- & less than A$100 per pair, or so I am told.
The Alloy Intercooler & pipework was made by "ASE" in Adelaide. That's AutoSport Engineering. They are very good!! web at aseturbo.com
The Tank was produced by an Auto Engineer in Port Pirie, 45Km west of here, who builds Dirt Circuit cars amongst many other things.
Both from my cardboard designs.
"Scary Loom". Sure is!! Altho since that pic, I have removed about half of it, still more to go !! Then new wiring for instruments, Lights, fuel pump, control switches, etc.
Fitting the electric winch to the Trailer at the moment. About one more week should see the Trailer finished. Then back to the "little one" !!
Regards, Rossco.
