Adjust the links so that under braking the 90 degree arms don't touch the chassis triangular tubes ---- push hard down on the inboard rockers to check there is a little space . Tighten the lock nut on the 4 rodends or the thread could strip
Our chassis , I've noticed , can vary slightly in the tube positions so you may need to pack behind the slotted lower poly mounting bracket to get a hole drilled through the tube. 2 or 3 mm will be enough if anything at all . Piece of slotted alloy facing down OR a washer or two if you don't mind removing the bolt
When bolting the clamps tight , slip a little graphite grease around the bar where the clamps grip.(the 'bar' is 16mm--also clamps--but you can leave a 1mm gap until it settles/loosens OR it will become a shock absorber
If you find that the bar does touch the chassis under hard breaking , there is enough thread into the links to take a little off each end ok .
Having fitted it , I doubt if any of you will need more camber than 2 degrees and around 1.5 degrees on road only. Once the summer comes you can check better after a spirited drive by checking tyre temperatures OUTER - MIDDLE - INNER If temp's are roughly equal cambers ok. If inner is much hotter then camber's too much ---- if outer is much hotter then camber's too little . Don't forget that tyre pressures will affect this so make sure they're not too high/low ---- 16 to 20 psi depending on weight
LAST adjustment hole i.e. nearest the end of the lever WILL be best setting for most
