Exhaust Insulation
whiterabbit
Exhaust Insulation
Post by whiterabbit »
Does anyone know if this stuff is any good ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 34095&rd=1
If not what do you recomend?
Steve
Sounds as though it will be lighter in weight than the stuff I used originally and with good heat reflection.
alecmartin19
Post by alecmartin19 »
this sounds similar to some of the heat blanket used on the american aircraft I work on! It is wrapped around our air supply pipes in vulnerable areas. These pipes can reach over 300 degrees so I'd say this stuff, if similar to ours, would be pretty good!
