Is there anyone who could post some good photos of the hood from the inside and outside to show all the mountings of the hoops and any of the other mounting. I was lucky enough to get the hood Tony was selling, I would like to see it in place as only seen pictures of cars with the hood fitted so any close ups would be appreciated.
Cheers George
Ps happy new year to everyone hope you all had a good time, I did
Hood
Re: Hood
Hi George,
I trust you got it ok and are happy with it.
The bars were bolted to the inside lip of the fibre glass body shell between the door shut and the roll over bar. Both bars pivot on the one bolt through the ali brackets. I dont know if these are done already or if the builder put them in place.
I cant help much more i'm afraid but if you bolt the front to the top of the windscreen i think you will see what needs doing.
Re: Hood
Tony just got the hood on Friday and looks spot on thanks can you measure where the holes go to mount the backets on the side for the hoops and also any sizes of the male part of the stud that the pops on to if you still have them.
Cheers George
Cheers George
Re: Hood
that really was snail mail,
here is a quick piccy of the old mounting points in relation to the door, hope this helps.
Regards
Tony
Regards
Tony
