I have decided to tackle the noise issue once and for all......
The existing silencer is useless, although its 34 inches long, its only 4 inches in diameter but with a 3 inch bore so doesn't leave much room for silencing.
I have cut out the sill so i can get the biggest can possible in there. Rotary engines are notoriously loud as it is so I want some thing that will definitely do the job.
I can fit a 7 inch silencer in there with a body length of 28 inches plus exit/entry pipes. I will add my own tip so just want it straight.
It must actually do some silencing though and last a little while as turbo rotories are very hot. I'm currently at 104 -105 db at 4500 rpm and i would like it to be somewhere around 100 if possible.
Can anyone recommend someone to supply or make one for me? I need it by the weekend g
Who Can Make me a 7 x 28 inch silencer??
Re: Who Can Make me a 7 x 28 inch silencer??
Try googling SIMPSON exhausts and manifolds . Make it repackable though or you'll regret spending the cash You need basalt too
thanks rob, i have read your other posts about basalt so i will be requesting that.
A long way up to Leeds though for tony to get sorted by the weekend Simpson's are near Slough so not such a trek and they do everything from street to F1 plus cheaper than most opposition
